Midi channel
Ricard Magnusson336 views5 posts
  • Ricard Magnusson
    Hi!
    How do I set individual midi channels for every drum channel on microtonic? Trying to sequence it from Digitakt, but cant seem to separate the drum channels on different midi channels.
    If you put Microtonic into "Pitched Mode" it will play individual drums on MIDI channel 1 to 8 (and 10 is all drums as usual). This button:
  • Ricard Magnusson
    I solved it last night! Digitakt was sending the same note on every channel... Changed it and solved it :)
  • chao
    same problem here.all elektron stuff can't to do that even different midi channel,I think its Microtonic's bug.I am sure the midi signal comes from only channel2,3,4,5,6,7.but microtonic can only received all signal on channel 1.(I am sure its on pitched mode)
    See reply here: https://soniccharge.com/forum/topic/1207-microtonic-cant-received-signal-from-defferent-midi-channel-on-pitched-mode
