Microtonic - pattern chains by default?
The Benjamin233 views4 posts
  • The Benjamin
    I've noticed when loading up any preset, as I go to initially change the patterns, they are chained by default. Is there anyway to globally turn this off?
  • The Benjamin
    Alright, so upon further exploration this isn't indicative of every preset. It seems that one just has to go through the patterns individually per preset and click each of the chain buttons to enable/disable them.
    Am I missing anything on this?
    Thanks!
    Each preset contains 12 patterns and each pattern may or may not chain to the next one. This is stored per pattern and preset and cannot be turned off globally. Sorry.
  • The Benjamin
    Magnus,
    Thank you and no apologies are needed. After playing with many hardware and software drum synths for years, I've finally found "the one" in MicroTonic. Thank you immensely for creating this and thank you for the reply!
