Hi, I ám a new user and hear only 1 channel (of 8)of the microtronic. Use ableton live. What to do in the set up to hear all 8 channels of the microtronic?
My guess is that you are running the multiple output version of MicroTonic ("MicroTonicMulti"). Try the other one (the plug-in without "Multi" in its name) and you ought to hear all channels. If you want to use the multi-output version (e.g. for applying different effects to the different channels) you can create audio tracks for each channel and route stuff like in this example: LiveMultiOut.als(32.6kB, 1880 downloads)
... or you could use the excellent Drum Rack described in this post.
