Patternarium flash error
busterkeaton266 views6 posts
  • busterkeaton
    hi,
    i can't get the patternarium site running: Flash fatall error. I am using FF and have flash player installed, see attachments. Any advice?
    EDIT: Just read at Adobes site, that Shockwave Flash will be discontinued 09.04.2019....
  • Sam Saw
    I had this problem a while back, i hadn't changed any settings or updated firefox so it was a bit of a mystery.
    updated flash, uninstalled flash, re installed flash nothing worked.
    I changed over to Chrome browser for a week or two,
    It now works in Forefox again.
    I have Flash 31.0 r0
  • busterkeaton
    thanks for your experience, i tried chrome, iron, opera, edge but no success, i hope and wait for the same supernatural appearance you experienced.
    Should definitely be supported in Chrome, although you have to enable it for it to show up.
    In the same browser, launch the Global Storage Settings panel. What does the option say? Try setting it to at least 10kb and see if that helps.
    https://www.macromedia.com/support/documentation/en/flashplayer/help/settings_manager03.html
    You can also scroll the Website storage settings and see whats used and the limit for soniccharge.com
    https://www.macromedia.com/support/documentation/en/flashplayer/help/settings_manager07.html
  • ITommy Zai
    I was required to install a newer version of flash. So far, so good.
  • busterkeaton
    just tried again and it works now...
