Metronome Issues with PO-35
Jake Sibley230 views2 posts
  • Jake Sibley
    Hello!
    I recently acquired the PO-35, and I'm running into an issue with the metronome. The metronome is always on, whether or not something is plugged into the output jack and whether or not I turn it off in the settings. I'm not quite sure how to go about dealing with this, is this a problem anyone else has experienced?
    What kind of metronome sound is that? If it is a fast clicking sound, perhaps you've turned on the sync signal? Try pressing record+bpm and putting the unit into SY0 mode. Otherwise I have no idea. The 4/4 metronome is hardcorded into the recording function so it should not be possible to hear it when you are not recording.
