Purpose: I want to remodel a part of "Beatrich"(Firmware).
In the situation using with "SYNC" mode.
I want to up minimum of Clock Frequency on a little (above 30kHz)
The reason wants to improve sound quality a little more.
Do you know the method?
Hi Yuji!
Glad you like Permut8! I do too. :)
Unfortunately this is not easy. Permut8 has a delay line memory of 64k 12-bit samples * 2 for stereo and when you run in synced mode its sample rate is adjusted so that these 64k samples align with your song position according to the time scale you choose. This also means that the Clock Frequency also depends on the song tempo.
I can think of two (rather complicated) workarounds to allow for higher sample-rate If I were to create an alternative version of the Beatrick firmware:
1) Firmwares have an additional 64k 32-bit words memory (apart from the delay-line memory) that could be used to store every other sample, allowing twice the rate. The tricky part is that some of this 64k memory is already used for other firmware data. (But one could pack two samples in each 32-bit word.)
or perhaps easier:
2) If mono sound is enough, one channel in the delay line memory could be used to store every other sample instead of storing stereo data.
Regardless of which solution, increasing the sample-rate like this wouldn't be transparent to the end-user. You would need to put Permut8 in twice the synced rate, e.g. for 4 bars you would put it in 2/1. The unwanted side-effect to this would be that Permut8 wouldn't automatically align to the correct beat in the song. It would play in sync, but could be 2 beats off if you jump to a new position in your song.
Hi Magnus
Thank you for useful advice.
"64k 12-bit samples * 2 for stereo" is rules in Permut8.
It does not touch it in Firmware.
This is very important indication.
I was interested there.
What my understanding does not extend to is sad.
I want to use "Beatrich" in stereo Hi-Fi if possible.
The combination of "Beatrich" and Permut8 is superior to every Stutter Effect Plugin.
Mr.Magnus.
I want to certainly ask you.
Do you have the plan making Hi Fi version of "Beatrich"?
