Cannot install supplementary patches for synplant or microtonic
Justin Vieira1 249 views3 posts
  • Justin Vieira
    Hello everyone, I cannot install supplementary patches for synplant v1.0.1 or microtonic v3.0.1. I am on Windows 7 64 bit. Both plugins are installed to C:\VSTPlugins\Soni\cCharge and work perfectly fine in my DAW of choice (ableton live), but for some reason none of the exe's for supplementary packages are working, I keep getting a "You can only install this product on a computer where [synplant|microtonic] is installed" error message. Can anyone offer help?
    Hi Justin. The installer remembers which folder the plugin was installed in originally. It then uses that location to determine where to install the patch packages. If the plugins have been moved or if the installer does not have sufficient access rights to the folder, it will guess that the product is not installed correctly. If you run the Synplant and MicroTonic installers again and just reinstall over your C:\VSTPlugins\Sonic Charge folder, then you should be able to run the patch installers right after that.
  • Painprod
    This isn't working for Synplant under Windows 10 Pro.
