Compatibility mac osx Catalina
guillaume besseau1 035 views9 posts
  • guillaume besseau
    Hello, i'm asking myself if catalina will be a problem? i'm using microtonic and synthplant since ... i can't remembe. so i'm pretty afraid. Installer/uninstall program are 32bit but plugin i don't know.
    Hi. Catalina will indeed a problematic upgrade for many. From the brief testing that we have done, our plug-ins should work with some minor issues:
    1. Our uninstallers are 32-bit, so these will not work.
    2. In the system settings, make sure you allow apps downloaded from "identified developers".
    3. You need to reboot before using our Audio Units.
    4. The file browser buttons for "Go to Factory Presets" and "Go to User Presets" do not work.
    These are all the problems that we have found so far, but Catalina have not been released yet and Apple have changed some requirements already during the beta.
    We are currently working on a big maintaince update to all our software. It will fix all of the above problems and more. Beta test should commence fairly soon.
  • Tim Rowe
    Synplant crashes Garageband in Catalina , also Tracktion Waveform 10.
    The Garageband problem seems to be related to the SDK issue that also Cubase 10.5 suffers from. https://soniccharge.com/forum/topic/1447-soniccharge-products-crash-in-cubase-pro-10-5
    I have a solution for that now but we haven't been able to roll that out yet.
    I wasn't aware that there are problems in Tracktion too. Hopefully it is the same SDK issue, but I'll check it out. Thanks for notifying us.
  • Tim Rowe
    Cool. Looking forward to the solution.
    Will a notification be announced here?
    Absolutely. You can also sign up to help us test here: https://soniccharge.com/betareg
  • Tim Rowe
    OK. Done!
  • dougieb
    Yeah definitely the uninstallers. Synplant is popping up as well. Obviously all of this is known. No rush for me tho.
    Uninstall Sonic Charge Bitspeek:
    Version: 1.5.0
    Obtained from: Identified Developer
    Last Modified: 6/27/19, 2:33 AM
    Kind: Intel
    64-Bit (Intel): No
    Signed by: Developer ID Application: NuEdge Development, Developer ID Certification Authority, Apple Root CA
    Location: /Applications/Sonic Charge/Uninstallers/Uninstall Sonic Charge Bitspeek.app
    Uninstall Sonic Charge Echobode:
    Version: 1.0
    Kind: Intel
    64-Bit (Intel): No
    Location: /Applications/Sonic Charge/Uninstallers/Uninstall Sonic Charge Echobode.app
    Uninstall Sonic Charge Permut8:
    Version: 1.1.0
    Kind: Intel
    64-Bit (Intel): No
    Location: /Applications/Sonic Charge/Uninstallers/Uninstall Sonic Charge Permut8.app
    Uninstall Sonic Charge Synplant:
    Version: 1.2.2
    Kind: Intel
    64-Bit (Intel): No
    Location: /Applications/Sonic Charge/Uninstallers/Uninstall Sonic Charge Synplant.app
