Synplant Extreme Flower Power
philter4 684 views19 posts
  • philter
    This video shows Synplant VSTi triggered by a Max4Live MIDI Device called "LBC Synplant".
    LBC Synplant is a great MIDI Sequencer that let´s you easily manipulate / automate / sequence the most important parameters
    of the plant.
    you can download LBC Synplant here:
    LBC Synplant Max4Live Device
    YouTube Video
    All Sounds are created by 1 Single Synplant Instance. Except the Kick/Clap that comes from a KORG ESX.
    Music is some kind of Minimal/Experimental Techno but it shows what you can do with 1 single Plant B)
  • BoB SwanS
    Thats amazing! But i only have Live :(
  • Troels Nygaard
    Thanks for sharing man! :-)
  • philter
    thx for the feedback! i am currently porting LBC Synplant to VST Format , so that
    everybody/every host can use it. will need some to to finish it but when i got it
    i will upload it here on the forum.
    no problem mate!
  • BoB SwanS
    Excellent news!!! I look forward to it.
    Wow! This is exciting news! How do you port it to VST? Do you rewrite it in C++?
  • philter
    Now, unfortunately i can´t code C++ ( But Damn, i have to learn it ).
    I will try to Re-build it with Synthmaker, it will not be easy because synthmaker has it´s
    limits and i am no DSP Guru or friend of the ASM Code in Synthmaker.
    i´ll try my best. but please don´t expect professional hehe....
  • BoB SwanS
    I think you guys need to team up ;)
  • Troels Nygaard
    Isn't it in some way possible to save/convert a Max for Live patch to VST format? I understand you can do that in MAX/MSP? Right? I am very new to this :-)
  • BoB SwanS
    Not sure,I think MAX\MSP allows you to save to a vst that runs with the free Pluggo runtime.
    I am fairly certain Max for Live will not allow saving to vst,it only lets you save to a Max for live device.
  • philter
    that´s exactly right...
    i have tried to port the LBC synplant to VST format but until i use synthmaker (great prog anyways, but not capable of doing max4live-like things atm) i will not be able to port it. but i made my own idea how to make a nice plugin to control the plant....please let me know what you think of it...
    so guys this is what i have created until now...(forgive me my bad english please :rolleyes: )
    i created a VST where you can set up all the Synplant Parameters (except the DNA) for each note you play. means EVERY note you play with Synplant can have it´s unique parameter setting that will be triggered at NOTE ON messages. i have added A second mode where you can setup 2 different settings for each parameters and crossfade between them (like the pattern morph in microtonic 3). i will just do some finetuning, then i will release a beta-version for testing. if it´s okay for you (yes sonic charge i mean YOU!) then i will upload the test version here, otherwise i will upload it in my support forum and post a link here.
  • philter
    here is a little preview image that shows my plugin in KEYBOARD mode...
    VST *.dll is following soon B)
    Wow! Yes, please upload the dll. I think you need to zip it first for the forum to accept the upload. Looking forward to trying it out. Neat idea!
    So did I understand you correctly that the Max For Live patch can't easily be ported to SynthMaker? Is it the step sequencer features that are missing or something? (Never tried SynthMaker myself.)
  • philter
    voila, a rough preview version. i have tested it in VSThost and it worked okay. but i am not satisfied with the GUI structure so i will think about a better design. :huh:
    not quite right... it is possible to port it almost 1:1 BUT i am not sure that it will run as stable as the MAX4Live Device. Synthmaker has it´s "mystic" problems, that´s why it runs behind
    SynthEdit/C++ written plugin.but i use it just for fun and i still love it. :P
    i will upload the LBC Synplant Port plugin later when i have finished it
  • philter
    just forgot to say <you again: i love synplant ;) ...
  • BoB SwanS
    Cool! I did not realise you had got this far already , I will test it over the weekend and report back
  • BoB SwanS
    I cant get this to work properly,I have tried placing it on the same track as synplant and on a seperate track feeding midi into synplant, I do see some sort of response from the synplant gui(A slight flicker in the branches) when i press keys on the synplant note2cc vst, but no real audio evidence that its doing anything
    I might wait for the other port
  • philter
    i have re-launched this project....a first midi plugin (ADSR Envelope Generator featuring Control Change output) can be found here:
    http://soniccharge.com/forum/index.php?/topic/525-synplant-envelope-generator/#entry1764
    other plugins will follow soon ;)
