Bitspeek doesn't show on Pro Tools 12
Elettra Bargiacchi217 views3 posts
  • Elettra Bargiacchi
    Hi,
    I have just bought Bitspeek. I have already installed it, rerun my computer, but after that I can’t find it in my host program, which is Pro Tools 12. On the Bit Speek User Guide, Pro Tools is indeed even not mentioned, although one of the most common DAW on market.
    Can you help understand which is the problem?
    Thank you,
    Elettra
    Sorry, Pro Tools does not support either Audio Units or VST plugins. There are tricks to get VST plugins into Pro Tools if you wanna search the web and try that out, or use our plugin in a different host.
    If this makes Bitspeek unusable in your workflow, just contact me through the contact form and I'll issue a full refund on your order.
    Hi,
    just contacted you through the contact form. Yes please get back soon for a full refund.
    Thank you!
