microtonic multi output
anonymous4 157 views11 posts
  • anonymous
    How do I route the individual patches to different outputs in MicroTonic? In the software´s stereo plug-in there is an output A and an output B, in the multi output plug-in there is an A and a B as well. How do I route further beyond A and B, I haven´t yet figured this out.
    Hi Ulf. The A and B selector are disabled in the multiple output version of MicroTonic. Instead each drum channel is sent to its own stereo output. This is fixed, unlike the standard version where you have two stereo outputs, A and B and you can select which one to use for each individual drum channel.
    Exactly how you wire your project to use these separate outputs depends entirely on which host you are using.
    Which host are you using?
  • David Zimmer
    My question is similar. I am using Cubase 5. Do I need to create a separate midi track for each drum channel and route those drum channels to the appropriate midi track? Or is uTonic routing to separate audio tracks?
  • R.A.W.
    - DPZimm wrote:
    [...]Or is uTonic routing to separate audio tracks?
    Exactly, you need one MIDI track, but MT3 got 8 stereo outs, one per voice/pad. So you just need several audio tracks and route the audio accordingly.
  • David Zimmer
    I'm not sure what you mean by routing the audio accordingly. How do I tell uTonic how to route separate drum channels? I don't see anything under the preferences or under "midi config".
  • R.A.W.
    You don't need to tell MT3 anything. It's a host thing to route audio, MT3 just has 8 hard-wired stereo outs. And as I work with Ableton Live, energyXT and NI Maschine I cannot tell you how it's done.
    You need to consult the manual or online help of Cubase or Google on how to route audio of multi-out VSTs.
    We did go through this a couple of years back and made a short guide regarding multi out in MicroTonic. It is a bit dated now (2009), but I think it can still help.
    Separate outputs with MicroTonic
  • David Zimmer
    Thank you very much Fredrik I will give this a go tonight!
  • Stephan Ralescu
    Bitwig 3.3.1 not seeing the multi outs
  • Sjoerd van Geffen
    Can confirm. Multi-outputs can not be selected as an input source on another track.
    (MacOS 10.13.6, Bitwig 3.3.1)
  • ChrisL
    I thought I had the same problem in Bitwig 5.1.3 Windows 10. However, I found the fix:
    • Right-click the side panel of the Microtonic device in the Bitwig device view, i.e. essentially right-click the place where it says "MICROTONIC MULTI".
    • Click "Add Missing Chains".
    • Now you have all the channels as chains in a layered device, which is actually much nicer than having to create separate audio channels for each one.
    If you still want to do it the "traditional" way, you can, since now the outs show up if I create an audio channel and try to route it as usual.
    Hope it helps!
