Mixconsole script?
Paul Savio326 views15 posts
  • Paul Savio
    Hello and thanks for the awesome update. Where can I find the Mixconsole script? It didn't install with pack 1. Thanks for your help.
  • David Kurek
    The MixConsole Script is included in the Official Microtonic Scripts 2020.03.29.zip which you can find on the Download page.
  • oddi
    Even after downloading the scripts pack, I'm getting missing .pika errors with various scripts.
    I think the windows script zip might miss a few files. I'm getting errors on Euclidean, FMTool, MacroTweak and the MixConsole scripts. Downloaded both the update installer + the scripts from the site.
  • philip formby
    im getting that also
  • philip formby
    worked ok yesterday
  • philip formby
    Look what I've found in my DAWs plugin list
    Duplicates the first microtonic when open the scripts dont work
    The second one works fine !!!
  • philip formby
    try rescanning your plugins!!! in your DAW
    Odd! I wonder how you could have ended up with both versions simultaneously. Is this on PC or Mac?
  • philip formby
    PC running Mpc software latest version to be fair it's been like this for a year
  • philip formby
    Doesnt cause any problems I always click the second one and its fine
  • philip formby
    The first one in the list
  • philip formby
    The
    second one runs 3.3
  • oddi
    I uninstalled the update, made sure all was removed and downloaded both files again. Now the errors are gone.
    The installer saves a reference to where the .dll files have been installed. If they are moved, the uninstaller will not find them and you could potentially end up with two versions.
    Best way to get everything back to normal is to:
    • run the uninstallers
    • start a host, rescan, make sure no Sonic Charge plugins are found
    • make a fresh install.
  • Paul Savio
    Hey thanks for the quick response David, it works great. I have wanted a mixer for this for so long.
    And thank you Fredrik and Magnus for the free update, I hope everybody is staying safe out there!
