PO-35 dump?
Phil Mahoney313 views6 posts
  • Phil Mahoney
    Hi Magnus,
    Just wondering if I can get that PO-35 dump. I'd really like to try changing FX 12 on my PO-137 to the build-up.
    Thank you!
    Phil Mahoney
    Vancouver
  • Phil Mahoney
    Bump! Any change you could upload a PO-35 dump for my PO-137, Magnus?
    Sorry it took me a while. Been in "vacation mode." ;)
    Here are the PO-35 factory settings:
    PO35FactoryDump.wav
    In case you want to restore the PO-137 factory settings you can simply hold down [write]+[pattern] when you put the batteries in.
    If anyone else reading this owns a PO-35 and wants to try the "fm bend" effect from the PO-137 it can be loaded onto the PO-35 using this dump:
    PO137FactoryDump.wav
  • Phil Mahoney
    Thank you so much, sir! Hope you're staying safe and healthy.
  • Bartosz P.
    5 years later, but still thanks a lot for the dumps! I've bought PO-137 recently and was surprised about the effect 12 being different than the one in PO-35. Even the official PO-137 manual says incorrectly it's the build up.
    I wish there is an option to replace this single effect alone, while keeping the original Rick&Morty sounds.
