Permut8 on audacity?
Svante Karlsson198 views3 posts
  • Svante Karlsson
    Permut8 VST is giving me a error message when I try to load it inside Audacity. I'm on windows 10 on a 64bite processor. Any ideas?
    Hey Svante,
    I am sorry I missed this post. I hope you got it up and running? If not, it looks like you might be using the wrong plug-in? Since Audacity is only 32-bit, make sure you install the 32-bit plugin and not the 64-bit one by picking the correct installer path during installation. If you have a 64-bit Windows it will select 64-bit by default. You need to enable 32-bit manually.
