only slot 1
Bas Sarlemijn119 views3 posts
  • Bas Sarlemijn
    When I load a kit only the first one has sound. The other 7 are not giving sound. What am I doing wrong? Thanks, Bas
    Are you using the "Microtonic Multi" version instead of the standard "Microtonic" (only) version?
  • Bas Sarlemijn
    Hi Magnus, Yes that is the solution! In the standard it is working correct! Thanks for pointing that out!
