Microtonic - play pattern on key hold
SicTransitGloriaMundi116 views3 posts
  • SicTransitGloriaMundi
    maybe im blind but i didnt saw any possibiltiy in the manual to play a pattern only as long a midi key is pressed.
    there is a similar function for muting a channel but only mute not play pattern. i feel like the default behavior is best for live play, but when setting up an arrangement a pattern-play-while-midi-note is engaged seems more favorable as you dont have to include stops everywhere.
    ------------quote--------
    C2 to G2 48 to 55 Mute channel one to eight. The channel will stay
    muted for as long as the key is held down. Foot-
    switch (MIDI controller 64) can be used to sustain
    mutes.!
    ------------quote end ----------
    Try the "Retrigger Gated" midi mode in Midi Config:
    awesome, thanks !
    .. now i also found it in the manual 🥴😅
