Microtonic Multi outputs and chokes
Tinaxe106181 views1 post
  • Tinaxe106
    Hi Magnus, first of all, I'm coming back to Microtonic after a break and what a fantastic piece of kit it is! Anyway, using the multi outputs in Ableton Live I wanted closed hi hats on one output and open hi hats on another. However, I couldn't get the open hi hats output to work. I finally tracked this down to the fact that I had applied a choke group to both sounds and therefore both were coming out of the closed hi hats output. Is this a bug or is the code designed so that if two or more sounds share the same choke group, they also share the same output? Many thanks in advance for your help.
