Select Channel
Enthalpi207 views3 posts
  • Enthalpi
    Hi there,
    I sequence my microtonic with an Elektron Digitakt and control it with an Electra One midi controller.
    I made an Electra One template which allows me to tweak every microtonic parameters for each drum channel. I just have to select a channel and my Electra One shows me all the current values.
    The problem is I don't want to use a mouse to select a drum channel and if I use the "select drum channel with MIDI notes" feature, my midi controller page is always changing when a pattern is playing and I can't act on a single drum.
    I don't want to use either the pitched mode because it would force me to create 8 different Electra One pages and won't be ergonomic tho.
    Is there a way to do what I want to achieve ? Could it be a future feature as mute function can be reach by CC and not only notes ?
    Thank you ;)
  • Enthalpi
    Am I the only one ?
  • Moritz Abel
    Hi there,
    I am facing the same problems here. As soon a midi clip plays the notes it changes the chosen channel, making it impossible to perform on every sound individually;/
    But how to tell the plug-in that it’s getting MIDI from the daw or from a controller:/
    Also do I have problems with jumping parameters. While the controllers endless encoders sends the accurate absolute or even relative it jumps to the position of the controllers values:/
    Cheers mo
