Couldn't create URL for FSRef error keeping me from saving.
Jmob154 views9 posts
  • Jmob
    No matter how many times I click ok it just keeps popping up and blocking me from saving. how do I fix this? I just cannot lose all of the work I did today.
    for what it's worth, I had this happen in logic a couple of weeks ago.
    thanks in advance.
  • Jmob
    ok, I was able to delete Microtonic after some click wizardry. Does anyone have any idea why this might be happening?
    Never seen this problem before. Looks nasty. Is this happening to you both in Logic and Reason? When does it happen?
  • Jmob
    and now reason won't save because it says a file is not found. I'll tell you what, this happened when I went to youtube.
  • Jmob
    yes. both platforms. Latest OS, current versions of logic and reason.
  • Jmob
    Also, as I was saying above, it happened both times when I went to safari. I have adblock on as a safari extension. I know it sounds crazy but could that have anything to do with it?
  • Nicolas Julliard
    Same problem today in Ableton Live on OS Big Sur! I don't know how to stop it and save my project...
    I still have not seen this myself, but here is a crazy idea to try if it keeps popping up over and over and over: copy some text from this forum (or anywhere else) and see if it stops.
  • Jmob
    it just started happening again in logic. I was able to close the plugin window and it stopped but, when I tried opening it back up again, it only opened a tiny window that had a few controls. Very odd!
