Cyclone multichannel output ( audio )
gentleclockdivider gentleclockdivider271 views4 posts
    Last standfing obstacle
    Altough I have asigned the voices to different outputs in cyclone , and both enabled the outputs in the daw .
    I only get it to play over one stereo pair with the option of panning , but that's it , no output routing
    Phew this is more complex than I thought
    With each note on ( voice ) the audio stream appears at a diifferent output in a cyclic fashion .cutting of the previoius note .
    No one .
    So let's summarise
    I have a drumkit playing on channel; 1 ( midi 1 ) , a monobassline on channel 2 and a polyphonic synth on channel 3
    When I assign the polysynth to an individual output ( 5, 6 ) the voices are alternating between the outputs , so playing a seventh chords ( which consists of 4 notes ) some notes are cut off abruptly
    All I want is the three instruments to appear at different stereo ouptuts , without voices being cut off .
    Hope this makes things clear
    P.s. is this forum dead ?
    The manual clearly states that output settingts on the voice level can be overridden by the output settings in the performance tab .
    Still I can't get separate outputs without notes being cut off ( when playing poly chords )
    I wan't a chord to be heard on a selected stereo track , and not alternating between tracks when a chord is played
