I installed Microtonic, can't start it!
Tarkan Elsoy151 views2 posts
  • Tarkan Elsoy
    Hi! I have installed microtonic for threee weeks trial but can't start or find the plugin in Reaper. Any idea how to proceed?
    Thx
    Windows?
    During installation, make sure you select the correct version (32 or 64 bit) depending on what version of Reaper you are using. Also, note the Plug-in path displayed.
    Inside settings in Reaper, check that the path is included under VST settings and then hit Re-scan.
    It should then show up when you add a virtual instrument track. Bear in mind that our plug-ins are VST 2 and not VST 3 so look for them under the "VST" and "VSTi" categories.
