Mac Mini M1 Big Sur 11.3 not seeing Sonic Charge VST's as actual plug-ins
Jeroen Verheij302 views8 posts
  • Jeroen Verheij
    Also, I downloaded the latest installer, but the installer keeps saying it's the 2015 version?
    Not sure if this is an M1 Silicon problem? They should run through Rosetta I suppose?
    I can install the VST's, but Bitwig does not recognize them as being a VST.
    Any suggestions?
    Thanks.
    Where does it say it's the 2015 version?
    It shouldn't.
    It should look something like this:
  • Jeroen Verheij
    Thanks for the response.Yes that's resolved now after a restart, so the plugins are now up to date.
    But I can't run them in Bitwig studio. I get this error:
    com.bitwig.flt.library.metadata.reader.exception.CouldNotReadMetadataException: could not read metadata: Not a plug-in file
    I can run the plugins in VCV rack for example, but all Sonic Charge give the above error in Bitwig 4.0
    I'm not sure how well Bitwig handles a mix of architectures. Are you running the entire Bitwig application under Rosetta or not?
    maybe try this suggestion: https://www.kvraudio.com/forum/viewtopic.php?t=546757
  • Jeroen Verheij
    Bitwig 4 is now M1 Native and can handle X64 and M1 together, and yes I tried that cache delete and lost all links to all my plug-ins this way. Luckily I could go back through time machine.
    It's really weird. I had the Echobode running once, on it's own. Then installed through the Sonic Charge installer to upgrade and from then on all Sonic Charge VSTs stopped being recognized. I also dropped a note at Bitwig and hopefully we can find a solution.
    Thanks. We haven't had any major issues before with Bitwig. Bitwig 4 is still in beta right?
  • Jeroen Verheij
    Yes it is, we're working on it. Will keep you posted.
