It's getting time to wrap up this beta. We've made some minor fixes, skin support updates, and polished some GUI resources. If nothing major shows up within the next couple of weeks, this version is good for release!
Mac: Sonic Charge Microtonic.dmgWindows: Sonic Charge Microtonic Win.zip
This update will mess up positioning on custom skins that were made for the previous beta. Make sure you download and use the latest skins. To make it easier, we have a test version of the official skin installer ready, including a "brand new" skin!
Mac: Microtonic Skins.dmgWindows: Microtonic Skins.zip
If you've created your own skin, read about the graphic resource changes here. The .mtskin config file has also been replaced by a .scskin file with a slightly different format.
update: new downloads in post below...
Thank you. Legacy - so cool :)
Seems to work here on my end. Thanks for the update. The legacy skin, haha. :D Unfortauntely I wasn't on board back then, but it looks funny. Still looooving the dark skin, though. <3
Fantastic! :) Thank you. No blue steel skin? That's my fave
Blue Steele is gone.
- larserikJ wrote:- jethrobull wrote:Blue Steele is gone.
Ah, okay. Thank you for letting me know ;)
- jethrobull wrote:- larserikJ wrote:Ah, okay. Thank you for letting me know ;)- jethrobull wrote:Blue Steele is gone.
You're welcome. Might do some blue version of the tonica later, but I can't promise anything.
- larserikJ wrote:- jethrobull wrote:You're welcome. Might do some blue version of the tonica later, but I can't promise anything.- larserikJ wrote:Ah, okay. Thank you for letting me know ;)- jethrobull wrote:Blue Steele is gone.
Sounds great! (If you do) ;)
Hi Fredrik,
I can confirm that the new beta works very well and is stable here (Windows 10, i7).
However,, I have found some more minor inconsistencies in the GUI.
It has got nothing to do with the code, but it's only about re-aligning some labels in the background image (both Factory and Vintage Tonic).
One more thought (but tthis is a matter of taste, I suppose):
As the oscillator section and the noise section contain the same number of almost identical graphical elements, which are also laid out in a similar, symmetrical way, one could possibly think about of having these two section the same width (therby stressing the iidea a modular structure). But then, I am afraid, this would imply some more shifting of labels, even in the code. :-(
This might be a bit late, but any chance of adding (could be a much later version) a "parameter lock" function? At least for the Master output? I find the presets to be too loud and would love to just drop the output back a bit and lock it in place when browsing presets.
In Ableton i map an LFO to the Volume and set the min/max values to like 60 which locks the volume while browsing presets.
Just downloaded the betas but I'm not able to get any skins to show up in the skin choose on Mac/Big Sur. I see the files are in the correct place at the correct path.
AU or VST, and in which host?
Vst, Bitwig
I'll see if I can find a Mac with Big Sur to test on. Unfortunately, my laptop is too old to install it. Anyone else here that has run Bitwig on Big Sur and got skins to work?
Thank you Fredrik. Happy to help troubleshoot if I can.
"A couple of weeks" have passed, during which I made a small fix that unfortunately requires a new binary. So we're back to square one, having to test what I hope is the one and only release candidate of Microtonic 3.3.2.
Is there anything specific we could test, which could be crucial or so?
Either way: already installed and going to test it tomorrow! Thanks for the beta.
No skins show up in the Skin Chooser still in Big Sur. Not a big deal for me, but just thought you'd want to know.
Here's the latest skin installer, give that a try.
Thank You Very much !!!
Thanks so much. This works! Love the new skins!
Hi,
Multi versions GUI not loading up, regular one works fine
Bitwig Ver 4.04
MacOS 10.14.6
edit* I did a complete uninstall and reinstall which seems to have rectified it,
Great job
dB
Try the new public beta and the latest skin installer here:
https://soniccharge.com/forum/topic/1965-microtonic-3-3-2-rc2-public-beta
