sonic charge VST plugins crashing Ableton 11
Vince Mertes386 views3 posts
  • Vince Mertes
    I'm on Mac OSX 10.15.7 using Ableton Suite 11.0.5 (current version as of time of post). VST versions of Synplant, Microtonic, Microtonic Multi, Echobode, and Permut8 are causing crashes in any set they are added to. Sometimes the crash happens as soon as the plugin's UI comes up, and sometimes clicking on any part of the UI will cause the crash instead. Other times I'm able to change a setting or two before the crash occurs.
    It seems the AU versions of the plugins do not necessarily have the same issue, but I'm puzzled as to why the VST versions are crashing Ableton.
    Silly question maybe, but I assume you have downloaded and installed the latest versions of everything?
    It seems over the last month we have been getting a handful of reports of crashes in Ableton 11, but I have never been able to reproduce this myself nor have I ever received a crash report from anyone. I would really appreciate it if you could help me out with this.
    After the next crash, could you please locate the latest zip-file under Library/Application Support/Ableton/Live Reports/ in your home folder and upload here?
  • Vince Mertes
    It should be the latest versions--I downloaded the latest installer under my account. Curiously if I'm able to get to the "About" page on the plugin, for example VST Microtonic says 3.1.1 in that menu, but using the Get Info in my Plugins > VST folder it says 3.3.1 there. My AU Microtonic is 3.3.1 in the About page in the plugin as well. I've tried deleting the VST plugins and reinstalling from the updater, but this doesn't seem to change.
    For me the crash reports are in a different filepath (Users > [username] > Library > Application Support > Ableton > Live Reports). The path starting with Library you mentioned doesn't have an Ableton folder in it on my system, I'm not sure why.
    I've attached them all here, though, in case something is different per plugin--reproducing the crashes is consistent for me:
