Swapping microtonic from 32 bit to 63 bit DAW?
Hendrik Strehl180 views2 posts
  • Hendrik Strehl
    Hello and sorry, if this question is redundant. I purchased and used microtonic with Studio One 3, which is 32 bit. Now i upgraded to Studio One 5 with 64 bit, and now microtonic doesn`t appear in the plug ins folder anymore... What can i do?
    I still have to use the old DAW, because i produced an album, which isn't finished yet. But actually i want to start off with the new DAW.
    Thanks a lot in advance
    Hendrik
    Hey,
    During installation, you can select to install both 32 and 64-bit versions of Microtonic. Make sure you select two different paths to keep them separated. By default, they go into your standard VST folder under C:\Program Files and C:\Program Files (x86)
