Can't control Bitspeek with MIDI in Sonar X1
anonymous886 views3 posts
  • anonymous
    Hi!
    I'm running Sonar X1 Producer Expanded and just stumbled upon your plug-in Bitspeek!
    I really LOVE the sound of it, so I downloaded a demo to try it out.
    Everything seems to work as it should exept the MIDI-controlling. I've set it to "Configure as synth" in the plug-in manager, but i won't show in the list of plug-ins! =/
    Is this because it's a demo and everything will work when I buy it?
    Thanks in advance!
    /Samuel
    Hi, no that is not a demo limitation, it should work without registering.
    In the user guide on page 7 there is a detailed explanation on how to make it work in Sonar X1. Please note that if you have added Bitspeek to a Plug-In Layout already, that layout will remember the settings it had, so you have to remove it from the Layout, change the settings with the "Configure as Synth" then put it into a Layout again.
    Once Sonar handles it as a Soft Synth, you should be able to find it under Soft Synths instead of Audio FX when you insert an effect on an audio track.
  • Samuel Lidström
    Thanks for the help! :)
    I got it to work and bought Bitspeek right away! =)
    Awesome work, Fredrik!! Your plug-ins sound amazing! :)
    /Samuel
