MicroTonic Multi-out Drum Rack in Ableton Live
Joseph Caterinicchio3 058 views3 posts
  • Joseph Caterinicchio
    One more tip (on a roll):
    Ski Oakenfull has a great tutorial vid on setting up Microtonic with multi-outs in a Live drum rack, enabling you to take full advantage of the racks potential for effect chains, sends, etc.
    [Tutorial](
    YouTube Video
    However, if you use this configuration, you lose the ability to control mute and pattern changes with midi notes (C2-G2, C3-B3, etc.).
    There's a simple fix:
    In the first chain, change the receive note from "C1" to "All". Now mute, pattern, and all midi changes are routed to the Microtonic instance :)
  • Markus Zorn
    Thanks, really useful.
    I haven“t thought of it myself yet...and thanks for the simple fix suggestion, especially useful when I want to use it with the lemur iPad template. :)
  • braduro
    If I set up your alteration correctly, JoeCat, I should loose the play button on the C1 pad, correct?
