Disabling Microtonic Sequencer
Fmt Raphaël556 views3 posts
  • Fmt Raphaël
    Hi,
    I am controlling Microtonic in Ableton using MIDI, firing MIDI notes at it using custom scripts. However, various events (such as pressing play on Ableton) are triggering the internal sequencer. Is there a way to disable it globally and consistently? I do not want to use it or to trigger it by accident. My script is also triggering program changes, which can then lead to another internal pattern starting.
    So far I have tried:
    • not sending a MIDI note above the C-1 / C2 range.
    • double clicking the stop button (temporary solution) but patterns will still play after program change.
    TLDR: I want to get rid of the internal sequencer, just keeping the synthesis and MIDI triggering part. How can I do so?
    Thanks! What an incredible drum machine!
    Go into Edit MIDI CC / Keys from the main menu and disable the midi notes for the pattern choices and the stop button. Like this:
    After this you can go into MIDI Config and click Make Default
  • Jko Ggl
    How can I make this work with BeatSpace? I want to sequence the midi outside of BeatSpace/Microtonic
