How do I go back to the 'Original Tempo' after using 'Half Tempo'?
Keshav Laddha95 views1 post
  • Keshav Laddha
    Hi Team,
    How do I go back to the original tempo after clicking on half tempo? The Undo function is one way to do this - however - undo doesn't let you go back to the original tempo if you've made a bunch of changes after going 'half tempo'. One other way to speed up your sequence is by using the step rate - however - that doesn't help change the sequencing on the step sequencer back to the original tempo.
    Could someone help with this please? I just want to be able to toggle between half-tempo and original tempo easily.
    Best,
    Keshav
