Half of midi config options greyed out
Pablo Antxonne158 views3 posts
  • Pablo Antxonne
    Hi,
    I'm interested in changing some of the options in midi config in Microtonic, but I don't know why they are greyed out.
    I've checked the manual and the forum and haven't found anything about it, can anyone know what could be the cause of this?
    The options I'm talking about (the greyed out ones) are:
    MIDI CC operate on selected channel
    MIDI CC generate parameter automation
    Improve scaling of MIDI CC values
    knobs and buttons send MIDI CC
    I'm using Microtonic in Xubuntu 20.04 with yabridge, inside Carla. In bitwig I have the same behavior. In both multi and regular Microtonic.
    I've tried switching every other option in case one of them was deactivating these others, but no success.
    It's a limitation of VST3. If you can, run the VST2.4 version.
    https://soniccharge.com/forum/topic/2184-updates-vst3-and-more?~post10763
  • Pablo Antxonne
    Ok, I´ll use the VST2 then. Thanks a lot!!! :)
