No sound in Microtonic in Mixcraft 9 Pro newest version
Richard Schönfeld100 views1 post
  • Richard Schönfeld
    I am new to Microtonic so I am not sure if I miss something obvious but I simply cant get any sound out of Microtonic in Mixcraft. Looked in here, looked in the manual, did not find any solution.
    The problem is like described and documented in a video in a post from 2019 that did not have any solution in it.
    Sequencer and evrything is working fine, if I hit the drum buttons 1-8 it produces sound, if I put a kontakt drum instrument behind microtonic it has sound (as you can see in the attached screen) but Microtonic itself simply does not produce any sound from the midi it produces, no matter if directly (which sounds in the kontakt instrument) or with midi pattern dragged on the track.
