Using symbiosis VST-AU wrapper for macos arm / 12.3 sdk
ju2999108 views2 posts
  • ju2999
    Hi,
    I am trying to port my ancient vsts to macos arm / macos 12++... Those use your symbiosis vst-au wrapper to build an audiounit version.
    Is there any more recent version of symbiosis available? If not, how do think the effort to fix symbiosis would be? Is there an alternative approach you would recommend then?
    Thanks a lot for help!
    Greetings.
  • Kevin Reynolds
    I just did the same transferring all my old VST settings of a plug in to AU for Apple Silicon. I had to manually copy all settings on my old iMac load up an AU version and and dial in all the setting. Took forever. Interested if there is a software for this. I tried saving a preset from VST .fxp and you can't load it into a AU :( at least at my knowledge.
