I normally always the peformance as an fxp* since it's faster to load etc ..
But I wanted to try to save the samples in native format and cyclone gives a disk write protected message
I assume that is because the defaut floppy is loaded .
By default cyclone is always loaed with the demo disk , so I tried to create an empty image file using the online floppy bake tool but it doesn't allow the creation of empty disk images .
So simple question , how does one save samples and performances in native fomat ?
Here's an fxp file containing the performance and some samples , if anyone is able to save the sample in native-compressed format he she gets a virtual beer
THere is def.something strange going one .
If you just load cyclone , we can load the samples from the disk ( be it from wave edit+ utility load , or voice edit+utility load ) as expected .
Now , if we go to system setup+utitly and press 5 we can format the floppy ,
it will then say that existed info will be erased .
Press execute and again the disk write protection message appears
, but the samples on the demo disk are effectively deleted becasue they can't be loaded anymore .
So even it previously said " disk protected" , it did erase the image .
I found it out
I just created an empty floppy image ,(at least one sample needs to be inserted in the disk bakker) .
Then when typhoon os is loaded you can insert your floppy and save your samples on that new disk image
