Microtonic AU stops after some seconds
CØRE138 views3 posts
  • CØRE
    Hi guys,
    Microtonic suddenly stops (even with transport running) after some seconds. It only starts to play again if I change the preset. Any ideas?
    Thank you!
    Host?
    When the sequencer is stopped, the Play button in Microtonic should flash green. Then it is enabled to start in sync with the sequencer. If your Microtonic stops after a few seconds, check if the stop button has lit up blue, then you should double-check that you do not have any MIDI triggering the play/stop buttons.
  • CØRE
    Sorry for the super late reply and thank you for the support. Now working! Still don't know why but it does =)
