Microtonic Pika script error please help
JBDS1198 views6 posts
  • JBDS1
    include('stdlib.pika');
    include('resources/mdk.pika');
    for (ch = 1; ch <= CHANNEL_COUNT; ++ch) {
    rmsp = function() {
    args(@patch, @ch);
    var selectedPattern = selected('pattern');
    var numSteps = selectedPattern.steps;
    for (var i = 0; i < numSteps; i++) {
    selectedPattern.setStepData(i, {
    '@Note': random(0, 127),
    '@Velocity': random(0, 127)
    stamp(rmsp);
    Error: Script error: Expected '{'.
    function RandomPattern() {
    'Note': random(0, 127),
    'Velocity': random(0, 127),
    'Muted': random() < 0.5
    error
    function randomizePattern() {
    // Get the number of steps in the pattern
    // Randomize notes and velocities for each step
    function readPattern() {
    // Read notes and velocities for each step
    var stepData = selectedPattern.getStepData(i);
    println("Step " + i + ": Note = " + stepData.Note + ", Velocity = " + stepData.Velocity);
    error
    randomizePattern();
    error .. nothing works....how i can make this work???
    i know we have this function but i m trying to create somethis simple so i can learn.Thank you
    Hi. Hehe, this looks like a strange mix between PikaScript and JavaScript. Microtonic still supports these two different script languages, but PikaScript support is for legacy only. We've moved away from that and use only JavaScript for our new scripts.
    I assume you know the full documentation for scripts is available at https://github.com/malstrom72/microtonic-scripts-sdk
    getStepData and setStepData are not part of the SDK
    I strongly suggest you start by installing the JSConsole script found on github, if you haven't done so already.
    Next, learn about getElement and setElement. For example, to read the currently selected pattern, you use getElement('pattern'). You can type this in the console:
    and see the result:
    As you can see you will obtain a JS object for the current pattern with arrays like "fills", "accents" etc.
    So for example to randomize the triggers of all channels, here is what you could write:
    var p = getElement('pattern');
    for (var ch = 0; ch < CHANNEL_COUNT; ++ch) {
      for (var i = 0; i < PATTERN_STEP_COUNT; ++i) {
        p.channels[ch].triggers[i] = (Math.random() < 0.5);
    setElement('pattern', p);
  • JBDS1
    Hi thank you for answering and thank you for helping me understand... I have installed the JS console and Microtonic SDK, but all the time I'm getting errors, obviously because I'm trying to execute pika script in JS console JavaScript ( and because I'm not that good with scripting either,, but we all start from somewhere ).. And if I make a script in JavaScript I have to save the file as JavaScript ( js ) and Microtonic will execute that script as he is doing the same for the pika script? Thank you... I am trying to learn because I have some good ideas that we can use as scripts.
  • JBDS1
    and see the result:
    JS Console:
    S> var p = getElement('pattern');
    JS> for (var ch = 0; ch < CHANNEL_COUNT; ++ch) {
    !!! SyntaxError: Expected '}'
    JS> for (var i = 0; i < PATTERN_STEP_COUNT; ++i) {
    JS> p.channels[ch].triggers[i] = (Math.random() < 0.5);
    !!! ReferenceError: ch is not defined
    JS> }
    !!! SyntaxError: Syntax error
    JS> }
    JS> setElement('pattern', p);
    The Microtonic execut corect the random script , the console dose not... i think i have to learn more first.. :)
    Yeah, the console only executes one line at a time. If you remove all line-feeds from the code and paste as one long line, it will work.
  • JBDS1
    thank you ...
