Can't trigger the drum channels with midi in Logic Pro!?
Henrik Juhl109 views2 posts
  • Henrik Juhl
    Hi all
    I can't trigger other channels than nr. 1 with my midi-keyboard in Logic Pro. Even if I try to drag/change e.g. nr. 2 to a different key it still only plays nr. 1. I've tested both the Single and the Multi version - still no change.
    Anyone having the same issue?
    Thanks!
    HJ
    Can you check if you have "Pitched MIDI mode" enabled?
