Microtonic only plays first drum hit
Evan Miller200 views6 posts
  • Evan Miller
    in Microtonic, only the first drum hit on button 1 makes any sound. Is there any way to fix this?
  • AAV
    I'd suggest you start by providing some detail about how you're using Microtonic, which version, which host, etc. Are you trying to play a particular preset? Etc.
    Your post gives zero to work from.
  • Evan Miller
    Of course, my apologies. I'm using version 3.3.4 through Ableton Live 11 Standard. I've tried activating the other drum slots by clicking, keyboard and midi controller, but I can only hear the first one; 2 through 8 are silent. I've tried adjusting every setting and tried numerous presets.
  • AAV
    Are you using the single output, or the multi output version ("Microtonic" or "Microtonic Multi" (at least for the VST versions))? It's possible you have the multi version and don't have your outputs set up in Ableton Live.
    If you load up the single output version ("Microtonic") and load up the preset "AC Back to Back (120)" from the "Microtonic V3" folder, you should be able to hear each of the 8 triggers play a tone when you click on them with your mouse. If you start there, it will help to narrow down where the problem is.
  • AAV
    Hope you've got this sorted(?)
  • joe cavalry
    I am having the same problem.
    I'm using Microtonic Multi/6-Microtonic Multi (VST)
    Ableton Live 11 standard
    I can only hear channel 1
    the other 7 channels (2-8) are silent
    I do not know how to set up Ableton Live
    Can someone please help?
    Thanks,
    -j
