Hi
I would like to use several of the genopatch candidates - are they saved as preset files somewhere temporarily that I could grab them from or do I have to save each one individually? Would be nice if you could say right click on each one in genopatch and have a save option.
Magnus has provided a way to bulk export with scripting. See attached:
That's great... could you give me a little more information as to what I am supposed to do with them? I looked in the manual, but there is nothing about running scripts that I could find. There is a reference to scripting in the forum, but no "howto"
Thanks. Figured it out - duh! - save to the scripts directory and access via the little button at the top right of synplant window.
That's great! I'll ask ChatGPT to write a script for me based on this. I'll share this if it's successful.
Interesting idea... but I would have thought that chatGPT would have to "know" what bits of synplant are exposed codewise in order for that to work - some sort of reference manual or samples... not sure if there is enough around that it could have harvested...
looking forward to see how it goes!
Having all of the presets generated is pretty good... but I still think it would be nice to be able to right click on a candidate and save it so that you don't have to go through all of the downloaded presets manually to decide which ones were the ones that you liked and wanted to use in combination.
Where is the scripts directory for Synplant 2 on a PC? I see the Microtonic scripts directory:
C:\Program Files\Sonic Charge\Microtonic Scripts
Thanks
Edit:
I installed the Synplant skins and the directory C:\Program Files\Sonic Charge\Synplant Scripts was created. Put the scripts there.
It it possible to have a script load each genopatch candidate one by one and play each one in sequence?
just a thought, save the entire page of genomes as new patch type like .gnp and include the original sample
Found this thread and just clarifying - I just move that script into my Mods folder inside the Script folder right? I did this and got a message anytime I opened Synplant about needing to run Genopatch first but wouldn't have any new options after that initial pop up message or once I ran Genopatch.
I have the same problem, no new options, just a message "run genopatch first" , anyone?
EDIT:
Turned out that, when clicking "ZOOM" option in the menu, Synplant asks to choose a folder for presets to be saved :)
