Does Genopatch Use The Original Sample At All?
Spinowitz373 views5 posts
  • Spinowitz
    If you drop copyrighted content into Genopatch, is it 100% synthesized? Or is it using any part of the sample you dropped?
    Nope, no part of the sample is used in the result.
    Think of it as this; If you had been using Synplant 2 your entire life, you knew what every parameter did and how it would affect the sound of the patch. You were then given a challenge to recreate a sample inside that 100% synthetic synth. You quickly dial in a rough start, then listen to the result, tweak a parameter, listen again, and tweak again. This is what Genopatch does, but at hundreds of times per second, rendering Synplant sounds at hyper-speed. (This is why the process is so CPU heavy.)
    The end result are a set of parameters, a Synplant patch looks like this:
    SynplantPatch: {
    	branches: {
    		{ id: 0x2c3af5ae, length: "0.0%", volume: "0.0 dB" },
    		{ id: 0x2c3af5af, length: "0.0%", volume: "0.0 dB" },
    		{ id: 0x2c3af5b0, length: "0.0%", volume: "0.0 dB" },
    		{ id: 0x2c3af5b1, length: "0.0%", volume: "0.0 dB" },
    		{ id: 0x2c3af5b2, length: "0.0%", volume: "0.0 dB" },
    		{ id: 0x2c3af5b3, length: "0.0%", volume: "0.0 dB" },
    		{ id: 0x2c3af5b4, length: "0.0%", volume: "0.0 dB" },
    		{ id: 0x2c3af5b5, length: "0.0%", volume: "0.0 dB" },
    		{ id: 0x2c3af5b6, length: "0.0%", volume: "0.0 dB" },
    		{ id: 0x2c3af5b7, length: "0.0%", volume: "0.0 dB" },
    		{ id: 0x2c3af5b8, length: "0.0%", volume: "0.0 dB" },
    		{ id: 0x2c3af5b9, length: "0.0%", volume: "0.0 dB" }
    	control: {
    		atonality: "50.0%"
    		bulbMode: "standard"
    		effect: "+0.0%"
    		glideTime: "0.0 s"
    		modWheel: "0.0%"
    		release: "0.5971440091447243 s"
    		rotation: "0.0 degrees"
    		tempoSync: "off"
    		tuning: "0.0 sm"
    		velSens: "0.0%"
    		voiceMode: "poly"
    		volume: "-0.005416241992373093 dB"
    		wheelScale: "100.0%"
    		wheelTarget: "growth +"
    	format: 28
    	genome: {
    		a_color: 0.37924853
    		a_form: 0.12919016
    		a_freq: 0.038900424
    		a_mod: 0.35670647
    		a_noise: 0.64550745
    		adj_bass: 0.8090325
    		adj_clip: 0.5055739
    		adj_pan: 0.5
    		adj_treb: 0.7129661
    		b_form: 0.264979
    		b_freq: 0.9018018
    		b_mod: 0.6358286
    		b_noise: 0.6560027
    		b_sh: 0.81782746
    		env_kf: 0.39348173
    		env_loop: 0.5579247
    		env_tilt: 0.29696983
    		env_time: 0.79240614
    		flt_freq: 0.39777854
    		flt_kf: 0.70099765
    		flt_mod: 0.51137674
    		flt_q: 0.58132696
    		flt_sep: 0.88485235
    		flt_type: 0.7496978
    		fm_amt: 0.73404616
    		fm_mod: 0.7888576
    		lfo_amt: 0.8155933
    		lfo_bal: 0.55760056
    		lfo_dly: 0.24629058
    		lfo_rate: 0.5227795
    		mix_mod: 0.24946141
    		mod_atk: 0.5936737
    		mod_dcy: 0.558466
    		mod_sh: 0.66687834
    		mod_vel: 1.0
    		osc_mix: 0.6842248
    		rvb_atk: 0.4755971
    		rvb_chor: 0.56241447
    		rvb_damp: 0.4693172
    		rvb_len: 0.8796625
    		rvb_mix: 0.89878196
    		rvb_size: 0.30392656
    		saturate: 0.82128084
    		sub_am: 0.78118604
    		vol_atk: 0.9770791
    		vol_dcy: 0.295884
    		vol_fade: 0.64845675
    		vol_sus: 0.78099066
    	implementation: 29
    	layers: {
    		{ enabled: "on" },
    		{ enabled: "off" },
    		{ enabled: "off" },
    		{ enabled: "off" },
    		{ enabled: "off" },
    		{ enabled: "off" },
    		{ enabled: "off" },
    		{ enabled: "off" },
    		{ enabled: "off" },
    		{ enabled: "off" },
    		{ enabled: "off" },
    		{ enabled: "off" }
    	legacyMode: false
    	modified: true
    	name: "V7 742061486"
    	pitchAdjust: 0.19435142
    	seedId: 0x2c3af5ae
    That's it!
  • Manuel Senfft
    Fun fact: you can actually copy the content Fredrik posted here and paste it into Synplant. Nice patch, hehe.
  • Moe
    its not working
  • mikers
    Yes, it does. Did you get the curly brace at the end?
