Synplant 2 - MIDI CC to plant?
sam f.439 views7 posts
  • sam f.
    Hey all!
    Quick question about MIDI configuration in Synplant 2. I'm trying to figure out how to assign a MIDI CC value to the "plant seed" action, which was CC#82 in Synplant 1. Does that functionality still exist in Synplant 2? CC#82 doesn't appear to do anything, and can't find anything about it in the manual or in the plugin itself. It's the only thing I need to be able to tweak and play entirely from a MIDI controller, so I'm hoping it's just something I've missed. 😅
    And thanks for all the hard work on Synplant 2! It's absolutely incredible,1000% worth the wait.
  • Adam Jablonski
    Similarly with random seed CC#83 :)
  • stelvia
    I'm also planning on mapping every single parameters to a controller. S2 not having a mod matrix makes it ideal.
    I didn't know you could plant seed from a Midi controller too, so thanks for the post.
    Curious to see where you're going with this. I'm expecting a Launch Control XL for the mapping.
  • sam f.
    Honestly I haven't even started to map too many of the settings, though I hope to soon! My current workflow is pretty simple: I have a cheap MIDI controller keyboard (Akai MPK Mini plus) and just use the mod wheel to grow/shrink branches, with one knob assigned to changing the mod wheel settings (Filter+/-, etc). I can audition a sound, grow branches, tweak settings....but can't plant the seed to continue. :/ Almost there!
  • Chris Lentro
    Is there a reason why the function was removed?
    Yeah, kind of. VST3. It's not impossible of course, but not straight-forward with how we create our VST3's. (VST3 and CC is a mess.)
    I will have a look at it again soon.
  • Jens Ã…gren
    Oooh... sound like a perfect occasion to make CLAP version then. :-)
