Feature request: some kind of sample export?
Pitter Patter620 views9 posts
  • Pitter Patter
    I think you are going to be seeing more of this request as many people are already noting how great this is for generating drum hits. It would be great if, in genopatch, there was an option to export each of the circular "nodes" that are generated on each strand as .wav files. Maybe figure out a way to export the branched out versions in the main UI as well.
    I know there is the slow, manual way to do this, but obviously it would be amazing if you could export with the click of a button.
    Cheers,
    Pitter
  • MT_
    Good idea!
  • The Benjamin
    You do realize that Synplant 2 isn’t sample-based, right?
  • Jmob
    That doesn't mean it can't export samples :)
  • Eine Alte Oma
    but what would that sample be like? on which note would it export? and what if there's something random in the patch, which is likely? nah, i think the only real way to make samples from this synth is to bounce stuff that you composed yourself
  • Pitter Patter
    The nodes in genopatch would take the pitch they have when you click them. Same for the branches in the main UI, which already only have one pitch until you make them the seed.
    Not sure what you mean here.
  • Dave
    if it exported a sample the same way serum can export a sample
    that would be amazing
  • The Benjamin
    Duly noted 😉
  • Dave
    YouTube Video
