Synplant2_Feature Request_Morph between two different sounds
matthew bonham102 views1 post
  • matthew bonham
    Just bought the whole package and enjoying it thanks!
    One thing I haven't found if possible yet (and coming from symbolic sounds kyma) is to morph from one patch/seed to another using a slider/midi cc.
    I did see you mention that you can take one seed and use genopatch to iterate on it in such a way that it gets closer to the sampled sound as it progresses and this works geat.
    If there was a way to then automate this so you can more parameters (like you can in microtonic) to go from one seed to another this would be amazing :)
    Hope the request makes sense!
    Keep up the great work! :)
