Launchpad template for Permut8
Jan Henckell1 822 views3 posts
  • Jan Henckell
    Here is a template i made using automap 4.4
    The 4 upper rows are used for the 32 switches and the lower rows change the presets.
    The arm button toggles between 3 midi controls: off, bits and prog.
    I made this because i wanted to toggle the switches. With a midi keyboard you have to keep the notes pressed.
    It would be nice to be able to use the switches and change the presets without having to change the midi control mode.
    Cool! I have a LaunchPad at the office. Will try this next week.
    So you mean that you would like to have a mode where you can flip bits and change programs at the same time, for instance via different midi channels?
    Actually, you can change programs with Program Change messages, but perhaps you can't program the Launchpad to send those?
  • Jan Henckell
    Right, the pads on the Launchpad can only be assigned to cc and note numbers, no pc´s with automap 4.4.
    So a mode in which parameters and patches can be changed at the same time would be nice to have when using Permut8 as a tool for playing live, at least for me.
