Artificial Reverberation as VST Plugin
Ivan BROSCA251 views4 posts
  • Ivan BROSCA
    Hello,
    After trying Synplant 2 I realized that I am in love with Artificial Reverberation.
    I would really like to see the Artificial Reverberation module as a separate VST Plugin, where I could drag my sample and it will adjust the reverb.
    Are you thinking the reverb effect would analyze the reverb settings of a sample (and only the reverb settings) and set itself up to match it?
    It's an interesting challenge, but it would require a different approach than the one used in Genopatch, where the settings can be easily tried and improved iteratively by the algorithm.
  • Kymatika
    The Reverb in synplant is awesome, I think having it as a external fx (no need to analize or nmatch anything!) would be wonderful
  • Jurgen Karczewski
    I believe the new Fabfilter Pro R2 is something like this. It analyzes impulse-responses
