Failed integrity test Synplant2
Patrik Kindvall2 463 views7 posts
  • Patrik Kindvall
    I get "Integrity Check Failure" after 30 mins . Even though i uninstalled everything and deleted dll and reinstalled.
    That's not good. You say dll. Are you only running the VST2 version? Just want to be sure there's not a VST3 version as well (.vst3 file).
    What host are you running? Does it have a plug-in manager where you can see the exact path of the plugins?
  • Patrik Kindvall
    Hey, Yes I never installed a vst3 only vst2. and i double checked so there is only the vst2 .dll.
    I'm running ableton live. Yes i know the exact path and deleted it but keeps happening anyway.
    This is concerning. This error indicates that something might tamper with the binary on your installation. Could you please:
    1. Locate the vst2 Synplant.dll and zip it.
    2. Double-check that there is no Synplant.vst3 in C:\Program Files\Common Files\VST3\Sonic Charge. (But if there is, zip this one too.)
    3. Email us the zipped files (support@soniccharge.com)
    4. Delete the found .dll / .vst3
    5. Start Ableton, and make sure that the Synplant plugin is gone (if not, try rescanning plugins)
    6. Reinstall
  • Patrik Kindvall
    I think i found the fault. Apparently it was my antivirusprogram (Avast) that haorded a synplant file. I found it after searching through my harddrive. Couldnt delete it so had to uninstall my antivirus software. Now it works 6 hours + =). Thanks
    Oh wow. I am pleased to hear you solved this. Anti-virus programs can be a total pita imho. We will see if there is anything we can do to avoid this issue in the future. Thanks for bringing it to our attention.
  • RAMIO
    Hello patrick the same thing is happening to me what exactly is the relation between the antivirus and this error and howncan i fix it is there any possible ways i can fix this
