Scripting/SDK access to Genopatch?
Durin Gleaves92 views1 post
  • Durin Gleaves
    I'd love to be able to automate expanding my custom sound library using Genopatch, but it doesn't appear the parameters are available through VST interfaces. I'm not sure if that's because this is technically a modal dialog, or if they've been purposely hidden from DAW and VST access.
    Any suggestions on how I can programmatically access parameters to select a new reference file and export sounds from the effect UI? If not now, are there plans to expose these parameters to developers?
    Thanks!
