Synplant 2 and Recording Ableton 11 live
Ben Bayle513 views5 posts
  • Ben Bayle
    I'm very new to all of this. I'm using Ableton 11 Live and installed the trial of Synplant 2. I can make noise :) However, I can not figure out how to record my samples.
    I added a midi track that is tied to Synplant but when I record I get nothing....I have attached a picture.
    Again I'm very new to all of this. Suggestions are welcome. Yes, I watched videos and read through the forums. Just as a suggestion a very basic step by step on how to integrate the plug in and record from it would be huge. Most videos jump right in we more advanced knowledge.
  • JBDS1
    You should create an audio track , select a Synplant as audio source, Arm it like you did, cmd click and Arm also the Synplant, select Synplant , hit the record circle (not the dot), then play some notes on synplant... have fun
  • Ben Bayle
    This worked thank you very much!
  • TORLEY
    If you're doing this kind of resampling and cut-upping frequently in general, you may find Rolling Sampler to be pretty useful: https://www.birdsthings.com/
  • Ben Bayle
    Thank you that does appear to be useful once I get the hang of what I'm doing :)
