Synplant 2 won´t show up in Logic pro
Mathias Aavik276 views6 posts
  • Mathias Aavik
    I bought Synplant 2 today, it works as a standalone application, but doesn't show up in logic. I have restarted my mac and redownloaded the plug-in multiple times and it still doesn't show up in the plug-in dropdown menu. All the components are where they should be and the plug-in also appears under Sonic Charge - and is successfully validated - in the plug-in manager. Still it won't show up in the DAW. Any suggestions on what might be wrong?
    Thank you in advance
    Did you remember it's an Instrument and not an effect? They are added differently in Logic.
  • Mathias Aavik
    Yes of course. It says in the plug-in manager that Synplant is an instrument, but it doesn't appear in the dropdown menu for AU instruments.
  • Justin Huculak
    having problems getting Synplant to be in Logic. Can't access it as a plug in
  • Paolo Gottardelli
    Same problem. Did you risolve?
    Doesn’t show up on logic pro 11, but on Ableton yes.
    I’m using macbook pro m1.
    Thank you
    If you add a "New tracks", you can find it under the "Instrument" drop-down
    Alternatively, if you add a new software instrument ⌥⌘S, then change the "E-Piano" instrument through the drop-down.
