Midi "thru"
Jeremy Daw60 views1 post
  • Jeremy Daw
    Microtonic does not pass midi notes through to the next device. It would be convenient if it did as I would trigger downstream devices.
    I can work around in bitwig by placing a "note filter" device in front of microtonic and then using that as the note "transmitter". (It does no filtering, it's just there as a device for "Note Receivers" on other tracks to capture the midi that is on the microtonic instrument.
    My work flow is to get basic beats on microtonic, then move them to Bitwig for more editing.
