Synplant parameters not responding in Max 8
Mihai Traista55 views2 posts
  • Mihai Traista
    I try to use Synplant in In Max 8. The vst~ object sends out the parameter number when the user changes it in the UI. However, Synplant doesn't respond to incoming messages from Max for changing the same parameter. The video shows parameter 9 - Volume.
    Any help with this? Thanks in advance!
    Synplant_Max8_Param.mov
  • Mihai Traista
    Found it. I had to send [parameter_enable 1]
